MO-2
Discussion in 'Heidelberg Printing Presses' started by Beguin, Jul 8, 2020.
  1. Beguin
    Beguin Senior Member
    Jan 2020
    348
    Côté d'ivoire
    Hello everyone, I have a problem with an MO-2
    two colors. when you press the start button, the signal is heard but the machine does not start. and it marks these (SBM_1 / 2 000F)
    thank you very much for agreeing.
  2. CHOCK
    2,874
    Normally the power converter part SLT, has MANY parts But mainly:
    1) SBM1 power bridge module 2) SBM2 power bridge module +3)SVT X1+X2
    2) I recommend that you measure the power supply first: a) NTK +24vDC supply : provides to operation panel +signal lamps+solenoid valves+brush monitoring main motor b) the other power supply NTK +24Vdc provides: brake of the main motor +contactors central control cabinet c) NTK +5vDC Supply for all electronics Board in the computer plug in unit REE+SSE
    3)The tolerance in all cases will be 0.7% up or down, if the voltages are NOT in the range are FAULTY.
    4) Measure any Fuse in the power supply if the power is NOT there
    5) the SBM1+SBM2 power rectifier bridge can be OPEN OR SHORT-CIRCUIT TEST IT.
    The main reason for Faulty Error is coming from the above mentioned
    5a) please see for any loose wires, or connector, or dirty or corroded.
    6) Use some personal tech or Engineer with good Skill for Electronic/electrical background
    Good luck
    Blessing
  3. Beguin
    Jan 2020
    348
    Côté d'ivoire
    Hi mister Chock.
    NTK input voltage:
    NTK5. = 30,59
    NTK24 = 35,52
    NTK24 = 35,57
    Output voltage:
    NTK5 = 5,2Vdc
    NTK24 = 23,87Vdc
    NTK24 = 23,93Vdc.
  4. CHOCK
    2,874
    The NTK are o.k.
    The problem is
    the SBM1+SBM2 power rectifier bridge can be OPEN OR SHORT-CIRCUIT TEST IT. Replace it
    Blessing
  5. Beguin
    Jan 2020
    348
    Côté d'ivoire
    If you like, what is the bridge rectifier?
    I can't see it
    Please, a photo of the rectifier bridge.
  6. CHOCK
    2,874
    Here attached similar to Heidelberg module.
    Rules of forum, <*please do not ask for, offer, or share any copyrighted document such as service manuals or diagrams covered by copyright in any manner that would violate copyright. *moderator note: added for clarity.>
    Blessing
