MMI CONFIG_SAVE_ERROR
Discussion in 'HP Indigo Digital Presses' started by Kishanpatel, May 23, 2024.
Tags:
  1. Kishanpatel
    Kishanpatel New Member
    May 2024
    India
    Machine show this error when start.
    <V7.6.114/3269> Error in the Config Save utility sys TabRead of machineStatus Topic(0] machineState[0] failed with error 38
  2. shiggy
    shiggy Member
    Apr 2024
    8
    China
    type of machine?
  3. Impredisa
    Impredisa Member
    Jul 2021
    40
    El Salvador
    I would say it's just a bug, when the press software is booting it may perform an automatic backup of your press configurations, but when the software reads that the press is in OFF state it will fail showing you that message, after the press boots and you turn it on, it will normally do the scheduled backup.
    If you're not sure of it, you can go to the backup destination folder, usually located at: S:\ConfigSaveBackup\
    If you see that your last backup has the same date than the error, then do not worry, your press is saving your config as usual. In any case you should perform a manual config save periodically just to be safe.
    Kishanpatel likes this.
  4. Kishanpatel
    May 2024
    India
    Thank you for helping us.
  5. Kishanpatel
    May 2024
    India
    The machine is hp indigo 3000 series’s.
    Issue is resolved now.
    Thanks.
