1. The Color Printing Forum Marketplace Forums can be useful for members who know one another well from forum discussions and offline communications and wish to post presses, equipment, or parts they either want or have for sale or trade. However, caution and good judgement should always be used. Especially when considering any business with anyone not already well known to you and trusted, due diligence must be used to confirm details and identity and be sure the transaction is safe before any money or property changes hands. Always use good judgement and perform due dilligence and follow these guidelines.
Mimaki UJF-3042 MkII EX UV Printer
Discussion in 'Color Laser Printers & Copiers for sale' started by Teresa Keehner, Mar 27, 2020.
  1. Teresa Keehner
    Teresa Keehner New Member
    Mar 2020
    0
    Southaven, MS
    $16,000.00 - Only used for about 1 year. 11.8” x 16.5” enclosed print area reduces dust contamination and UV exposure; Eco-friendly with low VOC, GREENGUARD Gold certified UV-LED inks. Kebab tool included. Print on a variety of substrates, including plastic, metal, wood, leather and glass. Runs on RasterLink software. Attached to rolling table for easy movement.
    The UJF-3042 MkII EX printer combine higher accuracy dot placement with speed improvements of up to 20 percent over the previous generation. A fully enclosed print area reduces airborne contaminants, reducing re-prints and ensuring production stays on track. The UJF-3042 MkII EX printer is fully networkable with industry standard Gigabit Ethernet for multiple printer connections over greater distances ensuring the highest productivity. Production on a UJF-3042 MkII EX printer is made more efficient with an automated hot folder-based workflow. Users can take advantage of features in RasterLink6 RIP software such as the ability to build a template and auto-populate the data using Variable Data with the Adobe InDesign Data Merge function or third party VDP plug-ins, to create a table s-worth of personalized items. Ball screw table movement paired with precise ink drop placement results in precise image quality. The UJF print table uses threaded registration screws for repeatable media or jig placement. Combined, these features ensure consistent accuracy for maximum production and minimal waste. A vacuum table ensures better fixation of challenging materials. Utilizes an advanced algorithm pattern to reduce banding, delivering output that looks spectacular even at higher speeds. Combined with Variable Dot Technology, the resulting prints is smooth even in the mid-tones, solids and gradients. Utilizes finely tuned frequencies for each ink specific gravity and viscosity to precisely shape and place individual drops, producing images that are optimized even at lower resolutions. Continuously circulates White ink and reduces the need for manual maintenance and waste. Mimaki UV-LED system uses less energy than other UV types, has a longer life and can print into media that could be damaged by higher-heat systems.
