Manroland 202 Oil light (red) does not go off
Discussion in 'Komori Printing Presses' started by auchprinting, May 24, 2012.
  1. auchprinting
    auchprinting Senior Member
    Dec 2010
    51
    Glenside, PA, USA
    Found out that pressman was using wrong oil (hygrade motorcycle oil) --- drained oil, cleaned filter and started refill with the correct oil. I am not sure if the oil fill round gage reads or not, seems an oily color, but does not look like fluid.
    How much oil is held in the press? Can too much oil be added? Can't get the red light to go out?
  2. spike
    spike Senior Member
    Apr 2011
    139
    new york
    reclean filter make sure oil is half way on glass press will not run if filter is dirty
  3. auchprinting
    Dec 2010
    51
    Glenside, PA, USA
    Changed oil --- refilled at filter --- about 3-4 gallons --- does not register in glass (glass is clear but yellow) can not tell how much oil (though 3-4 gallons should be enough) also added about 2 gallons to the side of the press. Light still red --- check 3 fuses for the oil pump (in the coffin) ... I was wondering if there could be a blown fuse on one of the computer boards.
  4. auchprinting
    Dec 2010
    51
    Glenside, PA, USA
    Resolved the problem. It was a white Siemans circuit breaker in the coffin.
