Linus
I'm faceing a problem of impression engage/disengage timing. When paper is fed, the impression is engaged and the impression cylinder is imaged about 14" from gripper (6-7 in at tail side) before paper enters into cylinder so, the backside of paper is imaged also (about 7inch from tail side). Disengage of impression is ok. When changing the timing cam of impression on/off, the time of engaging is changed accordingly. If moved backward, the imprision On time will be correct but disengaging time will be incorrect, means the impression will release after 6/7 inches from gripper side. The impression engaging time is more than 1 revolution so the problem is occuring. Cam followers and Cam is ok.
Please advice.
Attached is Cam image
Please advice.
