Man Roland 700 Non Permissible Feeder Pile Movement
Sildon
2022
25
India
I am working on a Roland 700. I was facing the feeder non permissible pile movement up and down problem. I checked in the k001,002,003,004,005 contactors. Everything is ok and I checked the motor - also ok. Can you help me to find a solution for this problem?
  • I check the auxiliary contactor also that is also ok,but the problem is not solved
    I was checked that contactor also that is also ok,but the problem is not solved
    Did you check input card?
    You can contact at my mobile whatsapp:-00919810902830 for detailed troubleshooting
    Adjust the brake
    It is written on the brake.
    The problem is not solved. I am thinking it has some other problem. Do you have any other idea?
    Can you tell me about B814,B815,B817 sensor, and each sensor is indicating which one is forwarding or lifting suckers. How can I find out if the sensors have any problem?
  • these sensors are for suction head height control and B814 or S814 is for pile control via press foot, you can check the signal in the RTR computer rack
