John Van Hoorn
- 2013
- 31
- Northern Illinois
Roland 300 Parts for sale
10 80.91H40-0977 Needle Bearing
1 80.93E40-0870 Water Quick Connect
1 80.07G362905 Ink Ratchet Casting
2 80.91H40-9809 Needle Bearing
1 HF2520 Needle Bearing (1 Way Bearing)
1 81.07D903800
3 80.05A306919 Gripper
1 80.94A40-9424 PPL Drive Belt
1 80.94H40-7118 Bearing
2 80.99I30-0230 Top part above gripper (Lifter)
1 80.37X442798 Sera Pump
1 83.37X44-2828 Sera Pump Housing
2 83.37X44-2798 Sera Pump
7 80.04C30-0017 Coater Blanket Adj Bolts
2 80.37X44-2880 Sera Pump Check Valve
6 80.05F30-5774 Brass Nut Flanges
2 81.37X44-2777
2 80.37X44-2881 Sera Pimp Check Valve
1 80.93K13-8093 Air Valve
3 81.37X44-2854 Sera Pump Seal
2 80.91A40-1830 Brass Bushing
2 80.21C30-0419 Feed Belts
1 80.21F90-A464 Sucker Assembly
8 80.91G40-1553 Needle Bearing
4 80.91K13-9850 Feed Board Wheels
1 80.21C13-0493 Feedboard Brush Wheel
1 80.98L90-1986 Sensor
1 80.91G40-1528 Needle Bearing
1 80.21F13-A420 Assembly
1 80.21C30-0448 Bladder
3 80.91H40-3552 Shims
3 80.91G40-1528 Needle Bearing
2 80.91H40-3503 Thrust Bearing
12 80.11C30-3599 Nylon Headstop Guide Wheels
1 80.91H40-8553 Infeed Cam Follower
1 80.17D30-3790
1 80.17E13-5171 Delivery Rear Hoist Cable 1755MM
1 80.94A40-8030 U-Joint
1 80.94D40-2013 Delivery Motor Backstop Gears
2 80.93B40-0309 Water Valve
1 80.08A30-1645 Damp. Roller Arm
Part below are Good used or reconditioned
Good/used water pan motor 8Z.37M51-3677 ($3600 new)
ROLAND; R300 80.09B30-6766 INK VIBRATOR ROLLER #14 (2.795 X 29.527 X 29.527 EST.) -REFURBISH BODY IN HADRON PROCESS NYLON (still in crate)
009D277013 ceramic water pan roller (shaft repaired ) by Hadronics in crate
Botcher recovered rollers for R300 still in box & paper wrap
#59 form
#51 form x 2
#58 form
#60 form
#57 form
Meter roller x2
#46 form
1 81.07D903800
2 81.37X44-2777
1 80.17D30-3790
#59 form
#51 form x 2
#58 form
#60 form
#57 form
Meter roller x2
#46 form
