Magenta spitting...again
Swifty2
2013
300
Ma.
this time it is more like freckles....Are you ready for the fix from our tech..............
A piece of electrical tape over a manifold hole to adjust the suction..works like a charm.:cool:..This fix is almost as funny as our plastic bag over the carrier door to stop the open cover fault.
It reduces the vacuum to the upper dev housing manifold. I initially wrote the technical tip that your tech followed :) but I use a rolled up top off of a carrier box instead of the tape
Mark
  • We had this in a few colours, ended up cutting a bit from a spare transport belt and placing it between the pipe. Works brilliantly!!
    Mark
    Hi Mark nice one coming up with the fix!!!...Have you got a fix for the carrier door open message? We have replaced the door twice and it keeps coming back thanks!
    Er no. I have one machine with a plastic bag over it as well :) It works so we'll leave it there
    Mark
    We use a sheet of reusable adhesive vinyl for the open cover fault. Works like a charm. Our tech has our Igen so rigged I think at half of it came from Pepboys.
    HAHAHAHA YEP used tape to cover a hole once...my own doing, though.
    and the plastic...
    tech called me and told me to do that yesterday! L-O-L high tech equipment were running ill tell ya!
  • New Xerox part number for the interlocks...W.R.I.G.G.L.E.Y.G.U.M 5556058210004
    Hello Mark,
    I have been having a lot of problems with the black spitting and causing all kinds of issues. Where can I find this manifold hole so that I can put electrical tape over it?
    Todd
    It reduces the vacuum to the upper dev housing manifold. I initially wrote the technical tip that your tech followed but I use a rolled up top off of a carrier box instead of the tape
    Mark
