Problem with motor Komori SPRINT L225B
Dear Sir:
Hi i hope you are well
If your comments are true, that the motor is running without a Load.
has a LOT a result:
1) The motor inside the Windings(1-2-3) 3 phases motor, one of them
or 3 are Faulty , from electrical engineering point( as electrical eng P.E That I am)
the Tech terms:" Reheating". You have take some test with Mega-Ohmeter(special
instrument) for to test this king of Windings, in Motors,Generator, etc.
Of course too, maybe the Ball bearings is defective by lack of maintenance regular, and Brushes( if the have) worn. Some Newer machines uses the new tech brushless motor
2)the control electronic motor Board if they have can be defective, need test according with the schematic diagrams.
3)If they use Contactors or Relais, test them for Worn contacts, or coils Overheating and replaces.
4)Before to take action in Repair the motor or some else, please take that test, if you have some
schematic, please let me know, and send me for to analize, and guide you better.
