Dear sir Referring to our machine Goss M300 machine Nr. 842-1992 type D0178 I have problem with Pcq control system. When turning the machine on We found that all register and ink Motors on all printing units doesn't read on the screen, so that we cannot control registers and ink Motors in all printing units. The pcq give us the following message "FAULT INITALIZATION bubble memory do you want to reinitalize, yes no" Could you please help me to overcome Pcq problem?
Hi sir: 1) Perform a visual inspection : look for loose and broken wires, improperly seated connectors, loose or broken wires missing switch, missing jumpers. and so on. Chech for obviously damaged component(components burned or discolore due to overheating); Dust + dirt + tear +wear 2) Reseating Boards and components: Edge connectors are a common source of problems. Power down the system and remove the PC boards. Examine the edge connector for contamination and clean with contacts cleaner contacts. Reseat any loose components such as scoketed ICs) . Reseat the boards and power up. 3) Power supply checks: Check the power supply for missing voltages and voltages out of spec. A digital multimieter DMM can be necessary, as voltage specifications are quite tight: logic supplies for example: must be within + 5% percent of 5Vdc. All the multiple supplies and all must be checked. 4) Board swapping: Board swapping involves the substitutiono of a known godd board for a suspect one. 5) Clock for CPU: Check the frecuency with frequency counter or a DMM included frecuency counter( like Fluke DMM) 6)Reset CPU: reset cpu see the attached schematic. 7) Components ; Rusting+Dry+Colder joint solders 8)Cables; Corroded+Broken 9) Finally the most important tool or instrument a service technician can have is his/her senses: 1) Sight 2)Smell 3)Touch 4)Hearing Merry Christmas
Thanks for your reply Firstly we found problem with card And we changed with new one And we found - +15v DC power supply problem and changed with new one We cleaned all the computer case cards and checked the flat cable connector s We need to know how to reset or initialize bubble memory the pcq
Great that you find 2 problems. We need to know how to reset or initialize bubble memory the pcq ? Attached is there again the schematic how to Reset the CPU, you can Not Reset the memory, since the CPu control the memory, attached is there some schematic that i did, for idea how work the CPU+memory. o.k?
Thanks for your reply Do you have the schematic for this pcq I don't have schematic know You are certain That card called MOBO in the catalog
Thanks for your reply I do not have a dealer The catalog in my work Are you working at this pcq before
Thanks for your I changed defective PCB card by new one but I can't find MOBO card There is only processor card
Thanks for your reply The card called EFISYSTEME CMC16 Sn 972431 Which Ic is the cpu in the attached picture Which ic is the rom
