LPI vs DPI
Discussion in '4-Color Offset Presses +' started by dotfordot, Apr 15, 2009.
Tags:
  1. dotfordot
    dotfordot Member
    Apr 2009
    21
    Beech Grove, IN
    I am not new to offset printing. I have brokered offset printing for 5 years. I am familiar with calculus concepts using algebra. I know what to look for in print providers.
    It seems that whenever I am looking at high lpi rated print the dots are much smaller
    Also it seems that the higher the dpi the sharper image quality.
    Is there any type of relation between lpi and dpi?
    I have done tons of research to find out that people only know how to define and describe each, which I already understand. But I want someone to explain to me the relationship (if any) between the two. If you have to go into math concepts I am sure you won't stump me.
    Sorry for seeming like an idiot if this is a dumb question. But I am looking for an expert or two to set me straight.
  2. Printer Mike
    Printer Mike Member
    Apr 2009
    28
    Stockbridge, Georgia, USA
    More dpi gives more dots to form the lpi dots; Thus, less jagged, and more rounded lpi dots?
  3. dotfordot
    dotfordot Member
    Apr 2009
    21
    Beech Grove, IN
    Im not sure if this is what you are saying... so smaller dots give you capability for a higher concentration of lines(lpi)? I have made this deduction already, but i guess im just confused on why I see inconsistency of line screens with certain advertised DPI.
    IE 175 LPI @ 300 dpi or 250 lpi @ 300 dpi,, and etc..
  4. Printer Mike
    Printer Mike Member
    Apr 2009
    28
    Here's an example; If I image a toner based polyester plate on my 1200 dpi laser machine, the maximum decent looking lpi screen I can use is about 120 lpi. My film image setter has a maximum of 3000 dpi and has imaged at 200 lpi.
    Sorry, that's all I know. Hopefully, someone can answer the question better than me. I probably overkill with file sizes trying to be safe.
  5. dotfordot
    dotfordot Member
    Apr 2009
    21
    Beech Grove, IN
    LOL, I do too..
  6. madan
    madan New Member
    Jun 2009
    Mumbai
    LPI - Line per inch which is for positive outputing
    DPI - Dot per inch (also known as resolution) for printer output or computer screen display
  7. madan
    madan New Member
    Jun 2009
    Mumbai
    more DPI - image resolution - in photoshop - give more sharpness for Image (300 DPI, 166 DPI or for line art 1200 DPI etc.)
    more DPI - output resolution - for positive - give more sharpan positive ( 3000 DPI, 2400 DPI, 1800 DPI)
  8. klecman
    klecman Senior Member
    Mar 2009
    171
    New York
    DPI vs. LPI
    Coming from the computer business to the printing business during the first years of desktop publishing, I learned a bit about the two which caused a lot of confusion when lithographic people first started talking with computer people.
    My understanding is that dots per inch refers to the number of increments that the print head can advance in one inch. However, these are not necessarily discrete dots and at a certian point, the dots will overlap and appear as a continuous line.
    Whereas Lines per inch refers to the number of discrete lines that can be discerned through a magnifier. Thus the two have little relation to each other because the dpi standard does not specify the size of the dot.
    Dpi is the standard for printers and LPI is the standard for printing which does by definition imply the size of the dot. Therefore 300 lines per inch is usually a lot higher resolution than 300 DPI depending on the size of the dot.
    The pixel is equivalent of a dot for stating resolution on a video display. Thus on a 40 inch display, the pixels, or dots, will be twice the size as on a 20 inch display and will have only half the number of DPI on the 40 inch compared to the 20 inch display. Pixels refer to the total number of dots on one horizontal scan line. A resolution of say 1280 or 720 refers to the total number of pixels on one horizontal scan line. If you look at a video display through a maginfier you will see the individual pixels but when you look a an image printed by a desktop printer, the dots will merge into continuous lines when the dots begin to ovelap. It would make more sense if printer manufacturers would indicate the size of the dot when stating the DPI number. So in one sense, pixels are more similiar to lines since they are discrete and formed by a fine grid mask imbedded into the display screen.
    I would have to draw diagrams to make it more clear but I hope this helps.
  9. RichardK
    RichardK Senior Member
    Aug 2007
    685
    Derby, UK
    dpi - desktop printers, the higher the dots per inch the sharper the print
    ppi - monitor resolution and image files, including ccd arrays
    lpi - final plate output resolution: newsprint around 60lpi, sheetfed from 133 to 300 depending on platesetter/imagesetter and resolving capabilities of the plate/press/paper stock/ink combination
    All the above are subject to the golden rule: GIGO garbage in, garbage out
    If the original file is low res, say 72ppi, then you can add as many pixels as you like but you won't increase it's 'quality'
    check out www.b4print.com for detailed info on prepress issues such as these.
  10. klecman
    Mar 2009
    171
    New York
    So, scanners work in pixels per inch. I wasn't aware of that. But it makes sense because the first electronic imaging used equipment and standards from television and video. I knew that laser and inkjet printers operate in dpi because desktop image printing started with the dot matrix printers.
    When I worked for Kodak in the microfilm division we had a test image that allowed us to measure relolution in lines per inch. Film photography, then required no translation when set to burn a plate image so there was no translation confusion.
    I seem to recall that the first versions of desktop publishig software produced digital images in either dpi or ppi which did not match the normal screen standards used in printing. They generated Hewlet Packard's Post-Script files. If my memory serves me correctly, there was quite a bit of debate at the time in getting the two standards to match up.
    I recall a debate between a representative from Apple Computer and a fellow who had worked as a typesetter. The Apple representative argued that laser printers produced sharper letters than typeset print because the printers produced 300 dpi which she thought meant lpi.
    I learned the distinction by hashing it out with my brother, the printer. I came from a backgroung in TV, computers, and film photography and he explained resolution from the printing end.
    My brother was a consultant for a company who developed air operated oscilating rollers. He worked both in the design and testing phases. He was also hired by Crabtree to testify in several lawsuits involving printing quality from a couple of presses. He was able to convince the jury that the problems were caused by poor quality ink and bad chemistry rather than anything wrong with the presses.
    You certainly have a broad knowledge of all aspects of the printing process. It is difficult to explain to some people why you can't get a sharper image than you started with. But now with digital image processing, that may not always be true. I know from my studies in visual perception that the eye can be fooled into seeing a subjectively sharper image than can be measured by objective image analysis.
  11. RichardK
    Aug 2007
    685
    Derby, UK
    Hi klecman, you're making me blush again :)
    If you love and have enthusiasm for the work you do, you make sure you learn as much as you can....
    38 yrs in and I'm still only certain of one thing - there's still so much I don't know. :D
  12. Satweavers
    Satweavers New Member
    Sep 2009
    Los Angeles, CA, USA
    What Is The Optimal PPI For A Given LPI?
  13. Navigateur
    Navigateur New Member
    Sep 2009
    UK
    Hi Satweavers! Rank beginner/outsider here, but according to this website http://desktoppub.about.com/cs/intermediate/a/measure_lpi.htm
    2 x desired LPI for uncoated paper stock
    1.5 x desired LPI for glossy magazine stock
    The reason why the paper matters is because glossy stock is able to hold a higher resolution of lpi than uncoated, where the ink would soak and spread out more.
    So there's no mathematical formula per se, just choose a higher lpi for glossy, and then you don't need so much dpi.
    I presume you're trying to save print time, which is why you want the minimum dpi for your target lpi, yes?
    Regards,
    N
    P.S. a real mathematical formula would involve the physics of that particular paper, surely :p
  14. carlosls
    carlosls New Member
    May 2010
    LEON, SPAIN
    The MATH way: ppi > 2 lpi ... why? ... It is a linear systems formula for sampling rates:
    The sampling rate of any analog function (ppi, pixels per inch is the sampling rate made by a scanner for example) for an effective digital representation must be greater or equal to 2 times the maximun frequency (lpi, lines per inch is the frequency of printing) ... therefore, if you print at 250 lpi (we are talking AM, not FM or stochastic) you better have your images made at 500 ppi, although 300 dpi will continue working it will have better transitions and dynamic range with 500 ppi.
    Have you ever think why your CD player has a sampling rate of 41 KHz and even more? .... it is the same science ... the maximum audible frequency is 20 KHz.
    SR > 2 Fmax
  15. Marlon
    Marlon New Member
    Sep 2010
    USA
    Dot size
    Hi All,
    I have a basic and simple question:
    What is the size (in micrones) of a single and fine dot (not cell) on a tshirt that can come out from 230, 305 and 355 mesh?
    Another way of asking it is what is the thicness of a line from 230, 305 and 355 mesh?
  16. Meny
    Meny Senior Member
    Apr 2008
    772
    Israel
    This is simple - here we go
    DPI - the number of dots the printer (plate printer too) can electronicaly put side by side on one intch to form the image.
    LPI - screen rulling for offset - the number of dots / lines that will form the image dots in print.
    if you work at 100 LPI and use a 1200 DPI printer , every printing dot you put to paper will be built by 12X12 printer dots to form one printing dot.
    this makes your printing dot nicer & rounder apposing to a dot made by fewer printer dots.
    this is why you need a high DPI # in order to get nice and sharp dots at higher LPI.
    if you will print a 100 LPI printing dot at 200 DPI , every printing dot will be built by only 2X2 printer dots , i.e. 4 only.
    by having a printing dot that can differ from others in small details , you get more gray shades and a better image.
    hope this made the whole issue clear now - if not , talk to me , will be happy to dive deeper.
  17. Marlon
    Marlon New Member
    Sep 2010
    USA
    Dot size
    Thanks,
    I am looking for the size of a dot from those meshs I've mentioned that come out from a single hole/opening in the mesh.
    All I am after is the dimensions (on the tshirt) of the singe and basic dot that comes out from a screen. I need just 1 example.
  18. archipelago
    archipelago Senior Member
    Apr 2010
    60
    Midwest USA
    Marlon, it seems you are asking about screen printing not offset printing, right?
  19. Marlon
    Marlon New Member
    Sep 2010
    USA
    Dot size
    Yes,
    Screen printing on garments.
