maverick1971
- 2011
- 176
- South Africa
Hi everyone!
I am having a problem on my QMDI CLASSIC.
The press is sometimes losing pressure on start up. Pressure starts dropping as soon as we go onto impression. Drops suddenly from 9.5 bar to below 6 bar quite quickly. This however does not happen on every start up which is confusing. We have checked all the short stroke cylinders and have replaced one which had a slow leak around the shaft. The others all seem fine. All the air lines have been checked several times also - no leaks.
Some of the long stroke cylinders did have minor leaks and all of these have been replaced. So we no longer have any obvious leaks on the press but we are still experiencing a sudden loss of pressure on start up (randomly).
Can anyone please advise on what else we could check? The compressor is running fine - cuts off and starts up properly. I am at a loss at this point. Any help would be appreciated.
A point to note though - if we start running and we notice the pressure dropping - we stop impression, leave the press running and the pressure builds up again. We then go to impression again and the press runs fine. Really confusing!!!
Please let me know if anyone out there has any suggestions.........
Thank you
Thank you
