Leakage relay alarm (CP-tronic Display splash screen freezes)
Discussion in 'Heidelberg Printing Presses' started by mihail_c, May 1, 2025.
  1. mihail_c
    mihail_c Member
    Nov 2020
    14
    Kazakhstan
    Hello.
    We have SM-52p with CP-tronic console. After starting the machine "HEIDELBERG CP-tronic" splash screen stay displaying and dont switch to main screen. We found that power leakage relay in alarm mode. So looks like some part of electrinc perepherial don't starts guarded by relay. At the same time main-board functioning normaly (flashing red led) and feeder side display switches after boot from splash screen to error 02.
    Please advise what part of perephirial this relay controls. Were to find leakage?
  2. Mathew
    Mathew Senior Member
    Apr 2010
    637
    Kolding-Denmark
    Hello,
    The leackage is not important. Is it a low pile or high pile machine? Send some photos from inside the electric cabinet.
  3. mihail_c
    mihail_c Member
    Nov 2020
    14
    Kazakhstan
    It's low pile machine
    Here is the photo of cabinet
      File size:
      484.3 KB
      113
      File size:
      392.4 KB
      106
      File size:
      379.3 KB
      110
  4. mihail_c
    mihail_c Member
    Nov 2020
    14
    Kazakhstan
    By the way if it does metter two buttons on main console are blinking
    MRTYMM likes this.
  5. Adil
    Adil Senior Member
    Nov 2021
    1,398
    Casablanca
    Hi sir if this heidelberg cptronic stay displaying please try to reset the zsk board
    Good luck
  6. SM52
    SM52 Member
    May 2012
    6
    Utah
    Could you explain how to reset the zsk board?
  7. Adil
    Adil Senior Member
    Nov 2021
    1,398
    Casablanca
    There is a procedure to do that sir ,
  8. Andy muller10
    Andy muller10 Member
    Dec 2023
    45
    Around the World
    Based on my shallow experience, if main screen remains on its logo, that COULD be a malfunction between ZSK and others. first of all you have to make sure if +5volts and Minus power DC-lines are correct? Do you have +5volt on ZSK? after that, there are some tiny LEDs on ZSK as indicators, How about them, do you see a tiny red blinking LED on ZSK? You may need to take a look at electrical drawings or consult an electric/ electronic technician.
  9. Adil
    Adil Senior Member
    Nov 2021
    1,398
    Casablanca
    It s very simple you have to reset zsk on the x11 slot between 9-10 and 11-12 but there is a procedure to do
  10. mihail_c
    mihail_c Member
    Nov 2020
    14
    Kazakhstan
    Thank you for your answers everybody.
    - Regarding red LED on ZSK board - it is flashing as usual.
    - We have tested cable from ZSK to Main Console Monitor - it's good.
    - We have cleaned all sockets at ZSK board by contact cleaner
    - Also we have made test by swaping ZSK from working machine - The main console remains at the same state.
    I would like to reset ZSK by @Adil recommendation but Main Console Monitor are at electronic technician at the moment.
    Wainting information from him.
    Will keep you in touch.
    And thanks.
  11. mihail_c
    mihail_c Member
    Nov 2020
    14
    Kazakhstan
    By the way, all what could Heidelberg team recommend to us is to order his technician from other country offline...
  12. Andy muller10
    Dec 2023
    45
    Around the World
    How about the level of voltages? Do you see all the voltages at the output of NTM & ADSM??
    And if it is your first time for hard reset (as your press has Perfector) be aware it is very important to put your machine on straight mode, manually. Very important)
    (P.S. if I was there my first step would be to make a bridge on earth leakage detector (11-14) and then check all the auxiliary connections beside the either each thermal switches or fuses then the condition af ADSM, NTM). How old is this machine??
  13. Andy muller10
    Dec 2023
    45
    Around the World
    This is from Your photo and here i see alarm LED is on. Am I right>?
  14. mihail_c
    mihail_c Member
    Nov 2020
    14
    Kazakhstan
    Yes, You are right and my topic was started from this issue.
    Machine from 2001.
  15. Andy muller10
    Dec 2023
    45
    Around the World
    This device is not responsible for internal failures but it is using for monitoring the earth and leakage currents. first of all do it bridge and continue your investigations. I have already had the same condition on an OLD PM52. it was hanging and getting stock at start-up logo and I have changed capacitors which were on NTM and on EWK.( life-time of capacitors). and at my case, it was successful. So it depends on the age and work-hours of press and also the quality of main- electric power perhaps need to exchange the capacitors.
    Joe Burger likes this.
  16. mihail_c
    mihail_c Member
    Nov 2020
    14
    Kazakhstan
    Checked all power source by oscilloscope to exclude any noise. They are ok.
  17. mihail_c
    mihail_c Member
    Nov 2020
    14
    Kazakhstan
    Just finished checking communication between Console Monitor and ZSK by protocol analiser. Here is strange beheivior of ZSK. It sends initial package after power on (again and again). But analizer tells that they are incorrect. As result Console Monitor doesn't respond to they at all.
  18. Andy muller10
    Dec 2023
    45
    Around the World
    just curiosity :
    1. Have you ever try to do hard-reset (on the x11 (Male pins) a pair of jumpers connect between 9-10 and connect between 11-12 )?
    2. Is this possible if you swap or exchange the MTN board with a correct and reliable one?
  19. Andy muller10
    Dec 2023
    45
    Around the World
    I am speaking about the ripple current this is why lots of big capacitors are on Press on each electronics boards
    Measuring ripple current with an oscilloscope can be a bit tricky because oscilloscopes usually measure voltage, not current directly. However, wish you good luck coming soon
  20. mihail_c
    mihail_c Member
    Nov 2020
    14
    Kazakhstan
    I never tried to do hard-reset. So I am a little scared because of unknown pitfalls.
    But now I know from you that machine SHOULD BE IN STREIGHT MODE. And jumpers must be placed on 9-10 and 11-12 pins. Then I should power on and wait some time (How much?)
    By the way what you think should change after reset? What kinde of params will be reseted? May I loss internal configuration of machine?
    And unfortunatelly I don't have working MTN board around but will try find.
    Thank you for your sagestion.
