Hello you all, Attached a picture of the problem I have. The corners are not printed. I can print the adjust injectors pages, but what should happen here? How can I adjust the ink flow rate? The ink flow setup button I do not have. Or do I need to login as something else as operator. What are the passwords? The systab editor I found. Anyone an idee. thanks
Does the press have a BID engage/disengage wizard? It prints out 2 sheets for engage lead side and 2 sheets disengage tail side. Follow screen prompts and adjust values. Redo test after each side to confirrn good values. If press has this feature it'll get copy to the edges.
