KY26 Automatic Die Cutter Upgrade Kit (Add Auto-Feeding & Waste Stripping to Your Semi-Auto)
2020
26
Hongkong
Hi everyone,
If you're looking to scale your die-cutting throughput but want to avoid the massive $150,000–$300,000+ capital cost of a brand-new fully automatic press, we’ve developed a solution at Kylin Machines that might be a great fit for your shop floor.
We are introducing the KY26 Automatic Die Cutter Upgrade Kit with Integrated Waste Stripping. This retrofit kit is designed to transform your existing semi-automatic die-cutting machine into a fully automated production line without having to replace your current press.
Why Upgrade? (The ROI)Manual sheet feeding usually requires 2–3 dedicated operators per shift and caps throughput at around 400–600 pcs/hr due to human fatigue. By retrofitting your existing machine, you eliminate the manual bottleneck and turn an underutilized asset into a high-speed finishing cell.
Key Features of the KY26 Kit:
  • Zero Manual Feeding: A robotic swing arm auto-feeds sheets continuously, drastically reducing labor costs.
  • In-Line Waste Stripping: Features an integrated automatic waste stripping module so you don't need a separate station or additional headcount for stripping.
  • Double Your Output: Increases production speeds up to 900–1,200 pcs/hour.
  • Consistent Quality: PLC servo control delivers a guaranteed ±0.2mm precision on every single cut, eliminating registration errors caused by operator fatigue.
Quick Specs:
  • Speed: 1,200 Pcs / Hour
  • Precision: ±0.2mm
  • Machine Sizes: 750 / 930 Model (mm)
  • Material Capability: Capable of handling up to 7-layer corrugated board.
You can view the full specifications and watch a demo video of the kit in action on our website here: Kylin Machines - Automatic Die Cutter Upgrade Kit
Feel free to reply to this thread or send a direct message if you have any questions about compatibility with your current semi-automatic setup!
