Konica Minolta bizhub c364e faded print on one side
Discussion in 'Konica Minolta Color Laser Printers & Copiers' started by LOVE, Jun 1, 2017.
  1. LOVE
    LOVE New Member
    May 2017
    Nigeria
    Good day everyone,
    My name is Love,
    Please can someone help me with what to do to correct Faded printing problem on Bizhub C364e.
    Whenever the machine prints, oneside will be normal while the other side will be faded.
    I've changed the image transfer belt and the problem still persist.
    I'm an engineer but I've not encounter this type of challenge in all my years of service.
    Please I really need your contribution and guidance over this issue. I know there are more experience and intelligent people here.
    Thank you so much in anticipation.
  2. Biggs
    Biggs Senior Member
    Mar 2017
    244
    New Jersey
    This is throughout all Colors? Or does it seem more apparent or only occurring in one color?
  3. LOVE
    LOVE New Member
    May 2017
    Nigeria
    Thank you Biggs for your response.
    It is throughout all Colors.
    Please am sorry I didn't see your comment until now, maybe I wasn't sure I will get response from here. But your response has really encouraged me to be part of this forum.
  4. Biggs
    Biggs Senior Member
    Mar 2017
    244
    New Jersey
    This may sound extremely basic, but all the drums are in good shape? is it only on oversized media (12x18 - 13x19)?
    The developer is somewhat fresh? It's rare however to see all the drums show the same image loss at the exact same time, unless the machine has gone without maintenance for an extended period of time.
    Also, check the fuser, see if there is any noticeable wear on the edge of the roller/belt. It seems more likely that this could be the problem, this would effect all the colors. If it's not the fuser, there's still a good chance that its something upstream from the marking engine
  5. Biggs
    Biggs Senior Member
    Mar 2017
    244
    New Jersey
    I have a gut feeling there's going to be significant wear on that fuser roller. I hope that's it anyway.. easy fix.
  6. LOVE
    LOVE New Member
    May 2017
    Nigeria
    Thanks Biggs,
    Yes the drums are in good shape, also the developers. The drums and developers has been replaced with new ones twice. But the fuser unit has not been service before, just the way it came with the machine for over two years.
    So, your gut about the fuser roller may be correct.
    One of my engineer friends said the problem is from the print head, which I doubt. He said there is a setting inside the print head box that can adjust the error.
    I want to go with your gut that it may be fuser roller. I have a spare fuser unit that I can use to replace it. And if the problem remains, we can try other options.
    Thanks so much for your time.
    I truly appreciate.
    My name is Love, am from Lagos Nigeria.
    I love to network with engineers and printing entrepreneurs from outside my country, in order to gain more knowledge in printing industry.
  7. Biggs
    Biggs Senior Member
    Mar 2017
    244
    New Jersey
    I have to imagine each imaging unit has its own head. That puts us back into a scenario where 4 components must be failing at the same time. Possible, but unlikely. It must be a single component that effects the print as a whole . Either pre or post marking engine. It could be something between the imaging units and the fuser, or something in the last imaging unit before it enters the fuser. This would make sense, the theory being that the each color is laid down exactly as it should, until it hits the final imaging unit, thus disrupting the image through all colors laid down before it.
    I'm still leaning toward the fuser though ;)
    Take a peak at it. It should be noticeably blemished in some way.
  8. xfactor printing
    Jan 2011
    647
    united states
    I think Biggs is right looking at the fuser.
    Does the faded image happen only when you print duplex in the machine?
    Is the first side printed or the second side printed the faded one?
    Can you manually print the sheet twice instead of having the machine duplex and see if the same fading happens then?
    Does it happen on different paper stock as well?
  9. Biggs
    Biggs Senior Member
    Mar 2017
    244
    New Jersey
    The duplexing question is a good one. I should have thought of that. Something could be occurring during the duplexing process... leaving you with one good side, one bad side..
  10. MUGABIRA PAUL
    MUGABIRA PAUL New Member
    Dec 2018
    uganda
    hello sir ,did you try to change on transfer roller ,but if it persists you can change color high voltage board
  11. iraklis7302
    iraklis7302 New Member
    Feb 2022
    greece
    Hello all of you,
    I want to know if you solved this problem because I have the same problem too... at first my c454 printed only one side well, and second side was faded in the bottom. Now all pages and all colors are faded from left to right. Is there anybody who solved this problem please? I changed drums/devs/fuser and I cleaned 7 mirrors from polygon motor in laser unit.
  12. iraklis7302
    Feb 2022
    greece
  13. ScottCo
    ScottCo Member
    Dec 2019
    13
    Minnesota
    After printing the first side the fuser is not as hot when the second side comes through. This can cause the second side to have a slightly more dull appearance.
