Konica Color registration
Isah
2018
Abuja
My konical minolta bizhub c452 yello color not register, it's printing outline, please friends, how can I solve it? Please I need your help
It is possible that the imaging units are near the end. Only new drives will cause the printer to adjust itself and resolve this error.
Does it have some hidden error with initial P?
  • Color Registration Adjust
    NOTE
    • This menu is unavailable when the key counter is not inserted while only the key counter is set to set by [Service Mode] -> [Billing
    Setting] -> [Management Function Choice].
    (1) Color Registration Adjust (Yellow, Magenta, Cyan)
    (a) Use
    • To adjust color shift if there is any when comparing the original with copy of the plain or thick paper.
    • To correct any color shift.
    • Able to make an individual adjustment for each paper type of plain paper, thick 1/1+, thick 2, thick 3 and thick 4.
    (b) Procedure
    1. Call the Administrator Settings to the screen.
    2. Touch [System Settings] -> [Expert Adjustment] -> [Color Registration Adjust].
    3. Touch [Color Registration Adjust (X*)].
    NOTE
    • *: X= Yellow or Magenta or Cyan
    4. Load manual bypass tray with A3/11 x 17 or A4/8 1/2 x 11 normal paper.
    5. Press the Start key.
    6. On the test pattern produced, check for deviation between the black line and the line of each color at positions X and Y.
    7. Select the color to be adjusted.
    8. Using the [+] / [-] key, change the setting value as necessary. (At this time, only the line of the selected color moves.)
    • If the cross deviates in the direction of A, increase the setting.
    • If the cross deviates in the direction of B, decrease the setting.
    9. Produce another test pattern and make sure that there is no deviation.
    Please try it.
