Komori Spica529 Encoder
Andy muller10
2023
45
Around the World
Dear fellows
in brief here our Komori Spica529 powered by TOYO ED64sp frequency inverter as main drive and an encoder from Tamagawa Seiki, OIH60, TS5205N455
At local electric parts distributors, Tamagawa's products are not available and I MUST use Autonics instead. I have a little bit knowledge of electronic and want to ask you, guys if I am right:
its a hollow shaft type & incremental encoder of Tamagawa, I think output signals are as: Digital output A,B,Z and sine wave UVW. Right?
and probably with a coupling adaptor i should connect the main motor shaft to the next encoder. for example E50 series of Autonics.
encoder-jpeg.14765
Best Regards
Happy to hearing from you sooner
All suggestions are welcome.
Thank you
  • For the kind attention of whom may have Komori which be powered by TOYO ED64sp frequency inverter as main drive and an encoder from Tamagawa Seiki, OIH60, TS5205N455.
    There is a better and stable solution because the OEM part is quite expensive.
    scientia potentia est.
    Knowledge itself is power.
