Gregpearce32
Hi there
We have a 2008 LS529 with Harris & Bruno HB290 coating chamber In UK.
We have had it serviced by Harris & Bruno, had Clamps refurbished by Komori, Had a brand new 10bcm anilox engraved, but we are still getting A bead Of coating along back edge of the sheet.
We are running 1.95 stripping Kinyo material stripping blanket with 0.90 Folabase Soft U underblanket
Pressure between chamber and anilox is 30psi
Pressure between anilox and blanket is at minimum ( dials wound all way out)
Pressure between blanket and impression cylinder is at minimum (+0.20 above Thickness of micrometered thickness of stock)
Using Pulse Aqualine low curl Coating
Is there anyway i can improve on my settings?
Cheers
Greg
Cheers
Greg
