KBA Technotrans Problem
John Samuel
2020
Philippines
Good day to all mamabers,
I have a problem with our 3 technotrans unit with the alcomart AZR .
The units already prompting an error of IPA>18% we already done what is indicated on the manual
but the error still occurs. We also try not pump it with alcohol only water and solution but its still
indicating IPA>18%. Hope any one has experienced this before.
Thanks and good day.
Hi sir
Attached is there the sheet of calibration sensor firt in the intruction m
Let me know
Blessing
  • Hi sir
    Let me know
    Blessing
    Is this to be done on the alcosmart unit or on the console (technotrans remote).
    Thanks also for the reply
    Don,t know what to say, haven't run alcohol in 25 years
    Please go to the start menu:
    Go to level 2 for diagnosis troubleshooting.
    When the star key is pressed the calibration values(gain, offset) will be displayed
    Hello, if you have not yet solved the problem, try changing the membrane, the filter and the seal on the alcosmart (if the filter is saturated with alcohol it always gives you a bad reading). It is a flat filter of one color white.
    If it does not work with this basic maintenance then you have to change the gas detector inside and calibrate it afterwards; this intervention is done at the technotrans in your country.
    The duration of this operation does not exceed 15 days.
  • Did you find a solution to your problem? Even I am having the same problem. Kindly guide me on the process to solve this problem.
    Hi sir
    Please do that .
    Good luck
