KBA Please Wait... screen
Osama
2017
6
Karachi
Our KBA Rapida 104 (1998) computer boots DOS but does not go past the screen with the message "Please Wait..." on the lower right side of the screen.
see image
Please reset the Cpu in the motherboard, but however you must test First, attached is there the schematic how to do it, and example, that ou must sear in Google, Yahoo, or Bing, for Pins Schematic, in according with the CPU, that machine has.
1) Vcc in the Cpu. + 2) Clock in Mhz printed in the same IC from CLK 3) See if the ribbon or flat cables, are o.k, clean it and use deoxidising cleaner, VeryPowerful
  • Please clean very well Edge connectors of PCB
    This is 80% of common causes problems in electronics
    Blessings
    @ing,_dr
    The error is from the software, tray a backup hard disk and the error is out.
    Thanks for your help to solve this.
    To backup your files using an external hard drive, you typically connect the drive to your computer or laptop with a USB cable. Once connected, you can choose individual files or folders to copy onto the external hard drive. In the event you lose a file or a folder, you can retrieve copies from the external hard drive.
    And with this type of hard drive, would it be possible to clone the system? Since my goal would be to clone the hard drive to mount it on a spare computer, so if the one I currently have fails, I won't waste time replacing it, like plug & play.
    This hard drive uses an MS-DOS system. Honestly, it's a bit complicated for me because I've never used a system with these characteristics.
    I'm attaching a photo of the computer I want to replicate and of the hard drive it has.
    Thank you very much.
    Yu can do it. Only you must sure , if you have enough RAM.
    Blessings
    see image
    Good morning. I have the same problem in my KBA RAPIDA 104/1997. Did you solve the problem and how ? thanks in advance
