KBA marking problem
Chris Thompson
2019
Lincoln
Having problem with C1S stock being marked on coated side. This problem is random and does not repeat sheet to sheet. 2 pictures show the marking on the coated side and the uncoated side of the sheet above. 2 different papers are being used, problem only affects 1 of them. Paper affected is .012 C1S from Tembeck, paper not affected is Tango .012 C1S. Any ideas?
Hi Chris,
What is the configuration of the press?
I have already encountered a similar problem on a KBA with several varnish groups, do you have a varnish group out of pressure as a result of your printing?
The cause may be a light deposit of ink in it.
Or a deposit of ink / varnish on one of the many leaf guides in the press, causing these traces.
[From Google Translator]
  • Different stocks deliver differently because they’re made differently...and setoff is almost always random. Hard to say without being there but probably the stock having issues has more of a down-curl to it, and if so, it might be causing the gripper edge side of the sheet to contact the sheet below it. There are other possibilities, as well.
  • Having problem with C1S stock being marked on coated side. This problem is random and does not repeat sheet to sheet. 2 pictures show the marking on the coated side and the uncoated side of the sheet above. 2 different papers are being used, problem only affects 1 of them. Paper affected is .012 C1S from Tembeck, paper not affected is Tango .012 C1S. Any ideas? View attachment 7290 View attachment 7291
    If the transfer drums are in , take them out. you don't need them anyway
