stickycreationz
Hi all I have this ryobi 2800 it will not clean the plate at all. It will completely ink up. I cleaned ink off roller and all and put some ink on the plate and ran it with only water it will not clean it in does roll over it though. I checked with paper all the rollers and they are seem to all be adjusted well. Even when I poor some water on the plate when running it does nothing. I have changed and rechanged the water and fountian solution with different kinds all mixed right even with strips. Rollers are not in bad shape. I even used a different kind of ink
any input from you? I am wondering if I used a roller cover on the water roller touching the plate?
