IST UV dryer Error
Oscar12
2024
9
Indonesia
The dryer can run about 20 minutes, then "excess temperature under of shielding" error appear,
What is mean?
The cassettes reach to the maximum permissible temperature and then they shut down to avoid damages.
The main reason could insufficient coolant flow through the cassettes. There are flow rate indicators mounted on coolant distributor. Check if they show enough rate.
  • The Coolant Motor is working, flow indicator is good. But the coolant hose is hot, is it Normal?
    If the return hose is hot, it's normal. Possibly the thermo switches are faulty.
