Issue with Ink Motors on Heidelberg Speedmaster (2-Color) - CP2000 Screen
rasimzekaj
2013
25
Tirana - Albania
We are experiencing an issue with the ink motors on both sections of our 2-color Heidelberg Speedmaster press.
Below is a picture of the ink control panel from the CP2000 screen.
It indicates that most of the motors have a problem. However, when adjusting the ink levels (increasing or decreasing), all motors respond and move, yet they still appear as faulty on the display.
The ink roller also gets stuck.
Has anyone encountered this issue before? What could be causing this discrepancy? Any insights would be greatly appreciated.
Most probably one of the NT85 +/-8VDC power supplies in CP2000 console is faulty. Take them out one by one and make visual check for any burned components.
  • Most probably one of the NT85 +/-8VDC power supplies in CP2000 console is faulty. Take them out one by one and make visual check for any burned components.
    Thank you for your reply. Could this also be related to why the roller in front of the ink motors do not rotate?
    Possible to ink key motor mechanical jam plz check ink because ink in inside protective foil plz check
    Yellow error have many resons
    "During startup/working if position is not achieve in given time (in internal program" System give yellow error for inkzone
    Many reaon
    1) mechanical jam
    2) zero setting
    3) electrical issue like
    4) zero volt wiring fault
    5) foils fixing wrong
