atleinart
- 2010
- 1
- new york
Hello, I have had one problem after another since my service contract ended. I had to replace the black drum because of streaks on the paper. That cleared up. Then I lost communication with the printer completely. The box on the back of machine has an LED which is usually showing 88 or 00. When I loose comunication, it flashes FF. The FF's slowly fade also, sometimes stopping completely or extremely dim flickering.
I kept rebooting to try to establish comunication. I got it temporarily and went to print something. . . . which led me to another problem. My paper jammed in the fuser and I got a code. I am not at work right now and don't remember the exact code. I did google it to find alot of people referring to it as needing a replacement for my yellow drum.
I went into service mode and my yellow drum is at 400+%, so I probably do need to replace it. But....would that make my fuser jam?
I noticed that after taking the paper jam out of the fuser, when I went to lift the fuser back up into position, it didn't align right. I had to lift the 2 white hooks to get them to close/clip on correctly.
I was thinking that maybe there are sensers around the fuser that I might have touched to dust off some of the residue from the black problem. Or would the yellow drum being bad affect my fuser and cause it to jam. Or is the fuser just going bad? Is there anything in service mode that will tell me if the fuser needs replacement?
I am sorry for all the questions. But, this is what's on my plate and I am doing my best to fix everything I can myself. I can't afford to hire anyone at this point. My printing business is hurting bad and I need this machine.
Thanks in advance for any and all advise/suggestions,
amanda
amanda
