Intermittent Startup Issue Man Roland 304P,2001
Discussion in 'Man Roland Printing Presses' started by marg_lucas, Oct 11, 2021.
  1. marg_lucas
    marg_lucas Member
    Sep 2012
    23
    Australia
    We have a intermittent startup issue with a Roland 304P,2001 . The problem has come up a few times (not at all regularly) and we would simply turn the press off and on again. It is only in the start up. Once the the machine starts it will operate correctly. The press has not printed for 6 months but we have been starting the press up regularly to turn it over and do maintenance. It has been the last few weeks the problem as come up and now it is happening all the time. If we leave the press for a few days and don’t switch it on it might start up correctly. It has been suggested that the main drive may need replacing or the ADAPTOR OF HARD DRIVES TO CF needs to be replaced. Has anyone come up with this issue before and is the replacement of the adaptor the solution? If the replacement adaptor has to be replaced has anyone got the part from a machine that has been scrapped for parts?
    Margaret Lucas
    mlucas@asnewprint.com.au
    whatsapp: 61408358143
  2. Daniel.Sanchez
    Daniel.Sanchez Member
    Apr 2020
    70
    peru
    You can send video
  3. Daniel.Sanchez
    Apr 2020
    70
    peru
  4. Sandeep kumar
    Sandeep kumar Senior Member
    Jan 2018
    110
    Gurgaon
    Mr Daniel,
    If you think it is hard drive problem ,we can support you
    Regards
    Sandeep kumar
    Whatsapp: 00919810902830
  5. marg_lucas
    marg_lucas Member
    Sep 2012
    23
    Australia
    Thanks Sandeep. I will be in touch via whatsapp
  6. Asim Shehzad
    Asim Shehzad Member
    Feb 2021
    63
    Lahore, Pakistan
    Hi Daniel,
    if the hard drive is defective and you want replacement (Modified) it will include a adapter board with 2 CF cards from Manroland.
    WhatsApp:+923496630209
  7. Daniel.Sanchez
    Apr 2020
    70
    peru
    if you can replace the hard drive
  8. Daniel.Sanchez
    Apr 2020
    70
    peru
    My number 51998153233 WhatsApp
  9. Daniel.Sanchez
    Apr 2020
    70
    peru
    I have another CF and SSD adapter, it works fine
  10. Daniel.Sanchez
    Apr 2020
    70
    peru
    these devices are not man roland
  11. Sandeep kumar
    Jan 2018
    110
    Gurgaon
    Yes you can use any adaptor and cf card, not necessary it is from manroland
  12. drukman
    drukman Senior Member
    Mar 2016
    201
    Bulgaria
    The problem is in the operating system. DOS does not work well with CF. You just need to change the CF cards and reinstall the machine software
  13. Daniel.Sanchez
    Apr 2020
    70
    peru
    It's best with SSD
  14. drukman
    Mar 2016
    201
    Bulgaria
    CF or SSD same problem with DOS. .....short orders = lives 3-4 years
  15. Daniel.Sanchez
    Apr 2020
    70
    peru
    There is industrial ssd, the factory warranty is 5 years, for old machines, I think it's okay, the idea is to find a solution at the moment
  16. drukman
    Mar 2016
    201
    Bulgaria
    This is the first SSD I installed 10 years ago.
    Greetings.
