Insufficient pressure in pneumatic compressor.
Discussion in 'Heidelberg Printing Presses' started by shani2742, Sep 20, 2021.
  1. shani2742
    shani2742 Member
    Jul 2020
    14
    Saudi Arabia
    Good day,
    Dear all i am having trouble in speed master machine.when we start feeder it stops within 10 seconds with an error " Insufficient pressure in pneumatic compressor " i have checked the pneumatic sensor 11B14 and it is working properly.If i run machine without feeder it keeps running but the problem came just after turning feeder to on. 49E09560-CF28-45E4-8614-6E0EB5859A8E.jpeg
  2. Mathew
    Mathew Senior Member
    Apr 2010
    637
    Kolding-Denmark
    Hi,
    Your machine may have air leakage. Try to throw ON and OFF ink, dampening rollers on each unit. You should also check the pneumatic cylinder for impression mechanism. It's quite difficult to check it while the press is running.
    shani2742 likes this.
  3. asem alsafady
    asem alsafady Senior Member
    Mar 2016
    189
    Amman Jordan
    As Mathew mentioned, it could be also on of the pneumatic cylinders is damaged, in your case I think it is the pneumatic cylinder for feeder air, it is at the DS under the feeder cover.
    Send us feedback.
    Good luck.
  4. shani2742
    shani2742 Member
    Jul 2020
    14
    Saudi Arabia
    Dear sir,
    During machine running i was continuously checking the voltages at 11B14 and there was 5vdc permanent so it means there is no pressure drop in pneumatic compressor.is there another senoser which is responsible to check the pressure.
    Please guide
  5. ashok kumar
    ashok kumar Senior Member
    Nov 2017
    248
    india
    Check
    i4 value in diagnostic/ current value
    Sak
    If Average value is going down below 17 then air error will come
  6. shani2742
    shani2742 Member
    Jul 2020
    14
    Saudi Arabia
    Dear sir,
    I have checked its working properly.
    The problem is the error came and go within 1 second even i can't see the error so i make video to check what is the error.error comes in feeder menu with yellow indicator
  7. Beguin
    Beguin Senior Member
    Jan 2020
    395
    Côté d'ivoire
    hello dear sir, please is there no leak at the pressurization cylinders. check all the cylinders if there is no leak.
  8. Beguin
    Jan 2020
    395
    Côté d'ivoire
    filmed the console screen and observe the message which appears in red and disappears. if possible email me so I can see thank you bien.esmelbeguin@gmail.com
  9. ashok kumar
    Nov 2017
    248
    india
    Hi
    It seems presure sensor is malfunctioning and you car try with bypass.
    If need how to do pls drop a msg
    +919818492864
  10. asem alsafady
    Mar 2016
    189
    Amman Jordan
    Ashok is right
    You can check the gauge of the pneumatic compressor, if the air is actually leaking or it is the pressure sensor.
  11. Adil
    Adil Senior Member
    Nov 2021
    1,398
    Casablanca
    Surely there is a leak at the level of a pneumatic cylinder; remove the covers of the printing units and watch the pressurizing cylinders, dampeners, grippers etc ... You will find a leak at the time of printing
