Inpress control XL 106
Discussion in 'Heidelberg Printing Presses' started by printerscd, Oct 27, 2024.
  1. printerscd
    printerscd Senior Member
    Oct 2012
    93
    Europe
    Hello.
    We print on XL 106-8 year 2019
    I want to ask which is the better option to use and set the regulation for best -tuning automatically
    option 1 or option 2 ?
    Is there any difference between them in the reaction speed for automatic color adjustment?
    I mean setting the bottom button on display. Which one is faster to respond to fine-tuning the color?
    Thanks.
  2. Adil
    Adil Senior Member
    Nov 2021
    1,329
    Casablanca
    If you press Automatic ink regulation is done in almost 15 seconds, just the time it takes to transfer the ink from the inkwell to the printing plates.
  3. printerscd
    Oct 2012
    93
    Europe
    so which option is the best? 1 or 2 from my photo image?
  4. Adil
    Adil Senior Member
    Nov 2021
    1,329
    Casablanca
    Which menu is this in the option 1 please take a large picture
  5. printerscd
    Oct 2012
    93
    Europe
    i send picture from screen of 1,2,3 OPTION.
    Which of these printers do you use?
    Which one is the fastest for automatic color adjustment?
    Thanks.
  6. Steve F
    Steve F Member
    Jun 2013
    52
    Scotland
    Option 1 - Manual follow-up
    Option 2 - Automatic follow-up
    Option 3 - Haven't a clue :)
    Press the top right of the console screen, then press on option 3, and it will pop up an explanation bubble.
    Steve
  7. Adil
    Adil Senior Member
    Nov 2021
    1,329
    Casablanca
    We use option 2
    If you need to know the fastest one you can push one by one and see the time of each one by the green circle, when it becomes full it means that the cycle is finished
  8. Printman673
    Printman673 Member
    Sep 2023
    31
    Virginia
    Me personally I like to use the 1 time which is option 1 only cause if you get a hickey in your color bar it will flood the key, also if your ink water balance is not good the key will fluctuate to much. Better to keep it on 1 to get used to it
