Inkwell on AB Dick 9985
Discussion in '1-Color and 2-Color Offset Presses' started by Vikki, Feb 17, 2016.
  1. Vikki
    Vikki New Member
    Feb 2016
    Tulsa, Oklahoma
    I am trying to find out how to dismantle the inkwell for cleaning, the ink keys are getting stuck. :cool:
  2. spikeboy
    spikeboy Senior Member
    Sep 2014
    62
    new york
    hi vikki very simple unscrew all keys counter clockwise untill they come out may have to use plyer if the keys are
    locked with ink then remove 4 bolts under fountain and pry off. let keys soak in press wash and wire brush clean fontain as well when placeing keys back start from middle out .use 2mm feeler guage close fountain screw keys
    clockwise untill you feel slight drag on gauge remember MIIDLE OUT PUT GREASE ON KES BEFOREHAND. then put
    smaal amont of ink in fontain and even out good luck spikeboy
  3. ghuerth
    ghuerth Senior Member
    Feb 2012
    152
    Using plyers on the keys tend to damage thumb knob and forcing dry ink through threads can damage fountain tray. Remove nuts above keys to remove blade exposing dirty screws. Using a wire brush and blade to clean threads to remove screws without damaging threads in ink fountain. Clean and grease and reassemble. Spikeboy is correct, tighten from middle out, loosen from outside keys to middle.
