Ink suggestions
philjomz
2023
Manila
Hi.
Anybody knows what ink brand can I use to replace HAPA Ascepte UV LED DOD ink? It's too costly to use.
Our printer is HAPA H-823 digital roll-fed printer for blister foil for pharmaceutical products.
Thank you.
You may consider using alternative ink brands such as Marabu, Agfa, or Sun Chemical, which are compatible with HAPA H-823 printer. However, make sure to conduct a thorough compatibility test before switching to a new ink brand.
  • I had a similiar problem - I would recommend as above the Agfa range - I tried two others but Agfa came out on top
    Thank you for your suggestion. Will try to contact these companies. Regards.
    Did you find some alternative ink for Hapa digiprint? I'm searching too some alternative ink for Asceptic UV used on KM1024i printheads
