Ink on Cutter Blade
Duc
2009
10
United States
Not too long ago it came to my attention that the ink from the iGen is leaving residue on the cutter blade when cutting anything with a bleed. I don't recall this happening at other places I've worked, but then again maybe no ever said anything about it either. Our cutter says it's a big pain in the butt to keep cleaning the blade. Is this happening with any of you?
Wow, I'll contact the bindery to check, but I haven't heard of any issues.
  • Yes, it does. And its a rainbow of colors. Most noticeably REDs. I've even experienced it when cutting a single sheet using an exacto knife, having toner "cake" onto the sides of the blade.
    Typically, any heavy coverage, full-color bleed will result in a dirty blade. Our finisher simply tends to cut that last if possible. We keep a stack of our break-in sheets for cutting/cleaning the blade. That's not a regular practice however, but just as needed.
    The idea is that we're dealing with a plastic based toner. Friction just simply messes with that. That's been my experience. Hope this sheds some light. ;-)
    -Solomon
