Ink/Dampener DC Motor Drive by Allen-Bradley
Discussion in '4-Color Offset Presses +' started by Elginagain, Nov 22, 2020.
  1. Elginagain
    Elginagain New Member
    Nov 2020
    Washington State
    Does anyone recognize this drive? I purchased it from the Seattle Times auction at the Bellevue, WA printing press location. I believe they were running Goss presses there. It's an Allen-Bradley Ink/dampener dc motor drive p/n: 136140. I just need the instruction manual or some guidance on the jumper settings, inputs and outputs.
    Any help you can offer would be greatly appreciated!
    20201119_180905.jpg 20201119_180953.jpg 20201119_180941.jpg 20201119_180929.jpg 20201119_180914.jpg
  2. CHOCK
    1,738
    Will be difficult to fin some instruction or schematic for this Old model.
    However will be a good idea, to contact you the company Allen Bradley, since they did the design, and sold this unit.
    Is my recommendation.
    Blessing
  3. Elginagain
    Nov 2020
    Washington State
    So it's old eh? Like how old would you think?
    Finding info on this drive is proving very difficult indeed! My first stop in trying to find info on the drive was to contact Rockwell Automation who owns Allen Bradley. They had no info on this drive on their website. Called and spoke to them on the phone but they were unwilling to let me talk with tech support because I don't have a support contract with them. They told me to contact my local distributor and they would be able to contact tech support on my behalf. The local distributor contacted tech support for me and was only able to determine that Allen Bradley was likely contracted to make this drive for Goss or Hancho. Therefore any technical info about the drive would have to come from the respective company who had Allen Bradley build it.
    That's when I started researching what kind of presses the Seattle Times used and determined it was likely a Goss press. Unfortunately I couldn't figure out how to contact Goss to request info on the drive. Instead I thought I'd try the forum here to see if anyone could assist.
  4. CHOCK
    1,738
    ok, I saw:(
    Weel the only way, is search in Google, for supplier for Web machine used, for newspaper, and see if they have , and want to do
    the small favor.
    Is my final recommendation.
    Blessing
  5. Elginagain
    Nov 2020
    Washington State
    Just sent an email to the engineering team at Manroland Goss, hopefully they can dredge up some old documents about the drive.
  6. er.bajaj001@gmail.com
    er.bajaj001@gmail.com Member
    Aug 2015
    23
    India
    I/O
    TB 2 -
    + & - = 0-10V Dc Input for Speed (When Using Drive in Auto Mode)
    T1,T2,T3 = Tacho Gentrator Input from Motor
    TB1 -
    L1,L2 = AC Input (120 or 240v Depends What Output Voltage you Need)
    H1,H4= AC Input for Control Transformer(For 120 V Jumper H2 and H3, For 240 make it open(Please Reconfirm by Having a Look on Tracks, I did this Long time ago so don't Rember well))
    A1,A2 = Armature Output to the Motor.
    Hope this will help you
  7. Elginagain
    Nov 2020
    Washington State
    Thanks for the info that is very helpful! I thought it was a 4-20ma signal so I was trying to run it that way, which seemed to work OK. I'll try using a 0-10v signal instead.
    Any idea what the jumpers are used for?
