Impredisa
- 2021
- 63
- El Salvador
Hello guys, I've a problem with the water heater, it has been working for almost two years since the first one died, but today it refuses to heat. I don't know if it may be fixed but this is what I've done:
- I've checked water inlet flow from 3 way valve of the cabinet, the valve opens an closes when required
- I've measured voltage of the connector and the heater itself when activated and is reading 220V as expected
- I've tested heating different inks but water temperature read the same as the ink, it lights as if it were to work but it doesn't, it never gets higher
- I've checked the heater water outlet (where the temp sensor is located), and the flow is ok, water comes out instantly if i open the tube
Is it already dead or can I do something? or just get a new one.
