Indigo 7r
jetscreamer
2009
146
Kenilworth australia
Is it possible to change a colour position on the run? eg: move the yellow into the grip.
you can change the color print order in the software, is that what you mean ?
Job Properties > Separations>Ink (print?) order tab> select ink and use arrows to change ink print order
or did you need to move the image itself ? if its out of register, run the CPR first on the substrate you are running. If that doesnt fix it, you can move it manually, but i cant remember the exact names of the windows. ill post tomorrow
  • Yes move a colour manually, I know about ink order and cpr. Cheers
    From the drop down menu select problem handling, CE Applications, then tap the down arrow and scroll to the bottom, select shift registration tool. Run process. Select substrate, paper type, grain, then the separation you want to move.
