I can change the Ink setting in the printer software color. Adjust the color settings many times but this action repeat simultaneously in printing the documents. Please anyone can explain to remove this misunderstanding between printing process
Does it happen with all colors or certain colors? You'll have to explain your process more before anyone will be able to offer useful advice. What program are you printing from, what are your color management settings, and what printer are you printing to.
This is an hp deskjet inkjet printer? There are usually a number of settings you can change in the driver; desktop printers often have color "enhancement" options that may come into play. Also much depends on the paper -- are you using HP inkjet paper at least to start? I would start with hp paper. Try sending a simple cyan magenta yellow test sheet and see if they are printing pure.
