In what circumstances do metallic inks change color.
Discussion in 'Ink' started by Rowjck, Sep 2, 2014.
  1. Rowjck
    Rowjck New Member
    Sep 2014
    VA
    This applies to gold metallic with aqueous coating. Anyone ever run into this before?
  2. Rowjck
    Rowjck New Member
    Sep 2014
    VA
    Still looking for answers...
    This is a real world situation.
  3. spikeboy
    spikeboy Senior Member
    Sep 2014
    62
    new york
    this can happen if you have to much water or the ink and coating are not compatable
  4. Jruff
    Jruff Member
    May 2014
    13
    New Jersey
    I'm curious what exactly happened to the appearance of the gold? Did it change shade or did the AQ knock out the metallic? Was the AQ gloss or matte?
  5. Adil
    Adil Senior Member
    Nov 2021
    1,353
    Casablanca
    Hi sir
    Printing gold metallic ink with aqueous coating can be challenging due to the unique properties of metallic inks. Ensure the press conditions are optimal, with proper ink-water balance and controlled temperature and humidity. Experiment with different aqueous coatings, as some may interact better with metallic inks than others. Consider consulting your ink and coating suppliers for specific recommendations tailored to your equipment and conditions. It might also be helpful to collaborate with experienced press operators or technicians who have expertise in handling metallic inks with aqueous coatings.
    Goodluck
  6. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,105
    Vermont
    If color match and metallic properties are super critical I would suggest a press proof or at the very least a draw down from your ink company with the EXACT products being used in the production run to include paper. It doesn't require all that much effort or time to throw a little metallic ink into the press and swap out for the correct coating at the end of a shift with the plates that are already on the press.
  7. Adil
    Adil Senior Member
    Nov 2021
    1,353
    Casablanca
    Nice
  8. starcolorink
    starcolorink Member
    Jul 2024
    10
    us
    In most cases, water-based inks should not behave like this
