Manual Labeling Machine
Description
This machine is applied to label the self-adhesive label on various cylinder bottles and containers.
This machine is widely used in pharmacy, foodstuff, beverage, cosmetic and chemical etc
industries.
Features
1. Its price is very low; the cost performance is very high.
2. This machine can finish deliver, strip, label to various label at the same time, its
efficiency is higher than manual only by hand , reduce cost.
3. This machine equips inching device, so the label accuracy is +/-0.5mm, no air bubble, no wrinkle,
function is stable, raise the additional value of products.
4.Usage range is wide, applied diameter of 10-150mm.
5. Portable design, the weight is light, an area of small, easy operation.
6. Mechanical design, no electric, maintenance is easy.
7. This machine equips charging device of pedal type and handwheel drive, operation is easier.
8. Open frame, adjust the label of different size and change parts are all convenient.
9. Main parts are all made of stainless steel, useful time is long.
Specification
1.Label width: 200mm
2.Label length:320mm
3.Products Diameter: φ15mm-φ150mm
4.Products Heigth: 10mm -150mm
5.Max Outside diameter of label roll: φ240mm
6.Inside diameter of label roll: φ76mm
7.Max Labeling speed:20 - 30 pcs /min
8.Accuracy of labeling:±0.5mm
9. Machine Net Weihgt : 22KG
10.Machine Dimension: 650mm x 430mm x 500 mm
Company: EC Printing Machine Factory Limited
Email:
sales@printer-manufacture.com
