lantz_xvx
Hey all,
We've got a Konica Minolta Bizhubpro C5501, and we're having a hell of a time printing double-sided postcards.
Our technician advised against running anything heavier than 100#C through the machine, which is fine because that's our house weight for postcards and business cards. But it won't print duplex on 100#C, we need to print one side, then flip and print the other side.
On pretty much every job, the front-to-back registration is off. We've used the "Image Shift" option to try to balance it out, but this takes a long time of printing one sheet, viewing by light and measuring, and fiddling with it until it works. This burns a lot of time, toner, and clicks.
What could be the problem? The files should be set up properly. We do all of our pre-press in Adobe InDesign CS5, and when setting up our print-ready files, everything is lined up and centered on a 13 x 19 layout, to be printed on 13 x 19 paper.
We can't afford to spend that much on makeready for what should be simple digital jobs, and the time screwing around with it could be better used for other things. Any insight?
Thanks!
- Lantz
Thanks!
- Lantz
