ILD Initialization failed
Discussion in 'HP Indigo Digital Presses' started by BRC, Mar 17, 2020.
  1. BRC
    BRC Member
    Oct 2013
    22
    MN
    Good morning- I am getting this message "ILD initialization failed. Check connection between ILD and PC Cabinet. Check power connection to ILD". I have tried to check and trying to determine which set of wires goes to the pc from the ILD. Any suggestions? This is a 2010 3500.
  2. indigo2015
    indigo2015 Member
    Aug 2015
    35
    rome (Italy)
    Go to adjustment/full ild calibration do restore and try to reinstall the firmware 2/3 times.
    If it fails I think needs to be repare.
    If you need an old I have one. Send me a private sms.
    Regards.
  3. BRC
    BRC Member
    Oct 2013
    22
    MN
    Thanks so much. I will try that in the morning!
  4. BRC
    BRC Member
    Oct 2013
    22
    MN
    Hi Luca, How do I get to the firmware reinstall. Do I go through a full ILD print calibration?
  5. indigo2015
    indigo2015 Member
    Aug 2015
    35
    rome (Italy)
    No. Before you start the calibration you should see the option to do restore parameters ild and to reinstall firmware ild. If you dont have them is because your machine it's to old. Maybe you can uninstall it and send it to a friend with hpi5500.
  6. BRC
    BRC Member
    Oct 2013
    22
    MN
    Gotcha Luca. So I could uninstall the ILD and have them hook up to it to reinstall the firmware? Is this common?
  7. indigo2015
    indigo2015 Member
    Aug 2015
    35
    rome (Italy)
    Yes if you have some friend with this option you can uninstall it and send it to him to reinstall the firmware. It takes 5 min.
    But it's strange you dont have this option as I have a hpi3500 and I can do it.
  8. BRC
    BRC Member
    Oct 2013
    22
    MN
    Yes, this is a October 2010 install so I would think it would not be older. I am assuming that you are doing this in technician mode?
  9. BRC
    BRC Member
    Oct 2013
    22
    MN
    Hi Luca, Would this be in technician mode? I would think that I should be able to do it on my end
  10. rolermanto
    rolermanto Senior Member
    Dec 2011
    101
    italy
    Yes technician mode... ;)
  11. BRC
    BRC Member
    Oct 2013
    22
    MN
    Hi Rolermanto - When I am in technician mode and go to adjustments -> ILD full calibration - It just wants to run through a full calibration and I don't see the option to do restore parameters ild and to reinstall firmware ild.
  12. rolermanto
    Dec 2011
    101
    italy
    give me your email,
    i'll send you the ilx parameter file
    If you install TeamViewer or Anydesk on your press I can login and check the firmware.
    Let me know
