IGen4 What is the best calibration paper to use?
MikeBr
2015
North Jersey USA
Hi All,
First time using this forum.
I was trying to get a brighter paper to use for calibration. I presently use 80# endurance gloss text. I was told it has a 94 brightness. Xerox recommends 98.
What is everyone using?
Use what is recommended. Why? If you use a vastly different sheet it will fail CMT as it is programmed to read the patch colours on the Lab colour space of the paper that is recommended. Run Engine Check and System Check on the recommended paper and then run the profiling on the paper that you use. Most of my old customers had Colortech 120gsm gloss in stock just for this purpose
Mark
Ex Service Engineer
  • I use 80 gloss text, with no troubles yet. But I'm not the most color-picky person either. :) I dont mind adjusting for differences.
    We have a paper purchasing dept that orders paper. They do not want to use Xerox. Any other brands that can be recommended, again 98 bright 80# gloss text. I just was searching on-line nothing came up that was gloss. Does it have to be gloss?
    Does calibration paper need to be gloss text?
    There seems to be much more availability for smooth finish that is 98 or 100 brightness.
    They use 80lb gloss text as a base THAT WORKS WELL WITH MOST STOCKS. If you run lets say 11x17 ivory all day long ..you can calibrate on that stock and create a profile to run from.so basicaly you can calibrate on any stock!!
  • You can profile that stock to use that stock but not run a reliable Engine Check and System Check on that stock. I gave the reasons why in the above post
    Profiling, Engine and System check are completely different processes
    Mark
    Ex Service Engineer
    calibration media
    we keep xerox dce 80#T gloss on hand for that purpose, it works well.
