Ideal Triumph cutter error codes
Dawid
2008
Can anyone be so kind as to post the meaning of common error codes that appear on the lcd of ideal triumph EP cutters?
I can't publish the list, let me know the error code and I'll let you know what it means. Include the model number
  • I can't publish the list, let me know the error code and I'll let you know what it means. Include the model number
    Hy,
    I have problem with my IDEAL 4850 95 ep.
    Show me an error 15.
    What that means.
    Let me know please.
    Regard from Croatia.
    THNX,
    Ivan
    Hi Birdz - I see you are in Michigan too. I have an MBM Ideal Triumph 4850-95 EP service number 4850 0492 -- for the past few days when turning the machine on and hitting the green start button to calibrate the back gauge I started getting an ert4 message in the lcd unless I wait 30+ seconds or so after turning the machine on to press start. I didn't get this before, so I'm wondering what it's telling me before it becomes a larger problem -- any ideas?
    That is nothing to worry about. My MBM has done that for years if I hit start without giving it 3 seconds to " turn on " first.
    EP 5550 ERT 04 error
    I would also like to find out more about ert 04 code on the Triumph EP 5550 cutter. I just replaced the A1 board, and the machine is running again. I am afraid to turn it off, though, not knowing for sure what all that ert 04 error code entails. (As a note to others, I salvaged what I thought was a blown A1 board by replacing the v1 diode. A tech tipped me off to this and with a little solder and a few cents of diode, I repaired a board that was going to cost me a few hundred.)
    I am trying to find out what causes a flashing error message on my Triumph Paper Cutter model 5551-06 EP. I came in and turned it on and it flashes error message t 15. I've never had an error message on this cutter before so I am wondering what it is. I'm guessing something electronic on it went bad.
    I have an Error Code on my Ideal 4850-95EP Paper Cutter
    The error code is ERT-15, what does this mean?
    Please help me with an EBa 480 it uses a small pcb, it is giving error 14 and wont go in diagnostics
    paul
    Hello colleagues, I hope you are well. I am with the problem that the triumph 9850 -95 ep cutter does not lower the paper press or the knife. when turning on the equipment it recognizes dimensions but when pressing the buttons it does not react. Do you think it could be a problem for the relays? how could i check them? thanks for your help
    Colleagues, I have a problem with a triumph 5552. It doesn't adjust the measurements well. Is there any way to adjust or reset?
    For example, if I want to cut an 11/17 at 8.5, it cuts it at 8.45. please help
    Follow this Steps:
    U: Measurement below 9,00cm.
    A: Press start until the backgauge has
    reached the position.
    U: Dimension was not approached correctly.
    -> LED "S" does not go off.
    A: - press START once again.
  • Hi,
    Does anybody help with error 15 and error 17 for 5221-95 EP guillotine?
    Hello,
    If anybody still looking for the Error 15 code, its because of missing counter signal.
    In my case it was the weak motor, you can check by hitting it lightly with a screwdriver or something while pressing the start button, if it starts moving then there is the problem.
    Remove the motor and take off the top, clean the carbon brushes and all the black dust, I also used a light sandpaper to clean off the black stuff from the copper parts.
    Reassembly needs some patience but I just blocked the carbon brushes and springs with a piece of paper till I put everything together.
    Its good to go for another year at least till the brushes will be gone and then I just need a new motor.
    I hope this helps somebody while searching the internet like I did for weeks. (IDEAL 5560)
