dalki
- 2014
- 2
- croatia
Hello,
I cut bundle of 500 paper length of 32 cm to 29.7.cm When the blade come
down, the rest of the cut is moved to the left and went into the slot on the
left side on surface of cutting. That block the knife. Then I pulled out the
rest of the cut, and cut the paper to the end, but after that it will no
longer raise the hydraulic clamp. I tried to disconnect the cutter from the
power, tried with the reset button for the knife and clampo but no sucess.
The clamp is down and the indicator of oil preasure is on the midlle.
Also when I opened the bottom cover, I saw one black cord in a place where I
suppose it should not bee because it is too close to the moving parts and
free in the air. It leads to the upper part of the machine where is the
knife. Maybee to some sensor.
Please help.
Best regards
Dalibor
Please help.
Best regards
Dalibor
