ballykea
- 2008
- 184
- Pennsylvania
GRAPHIC WHIZARD CREASEMASTER PLUS +
Creaser, Score, Perf, STRIKE Perf
VERY GOOD CONDITION
$4000
2018 DUPLO DC 516 Slitter/ Scorer
Creasing: 100 sheets per minute, Cutting: 12 sheets per minute
Paper Weight 110-400 gsm
Slits Up to 10 per sheet
$11500
ProSeal 44 Board Pouch Heat Laminator (44") Really Good Condition!!
$3600
Challenge CMT-130 Three Knife Trimmer (INSTALLED NEW 2012 ) VERY GOOD CONDITION!!
$21,000
BURTON MARK V TAG STRINGER
The machine includes an automatic cover feeder and vertical stacker. completely self-adjusting perfect binder. The pneumatic clamp and nipper adjust automatically.There are two glue pots, one for side gluing and one with twin glue rollers which allows for an even glue application as does a third, metering roller to smooth out the glue
REALLY NICE Machine!!
$14,500
MCE SIGMA TABLETOP PERFECT BINDER
manual feeder
clamp 38 cm,
block thickness max. 50 mm
hot melt and side gluing,
creasing/milling
110V 60Hz
$2200
HORIZON BQ 140 Very Nice Horizon SINGLE Clamp Perfect binder
Good Condition!
$6800
HORIZON BQ 440 - 4 Clamp Perfect binder
*Number of Clamps : 4
*Maximum Book Size : 320 x 320 mm (12.6″ x 12.6″)″)
*Minimum Book Size : 75 x 75 mm (2.9″ x 2.9″)
*Binding Thickness : from 1 mm to 40 mm (0.04″ to 1.6″)
*Production Speed : 1100 books/hour
*Maximum Cover Size : 320 x 580 mm (12.6″ x 22.8″)
*Minimum Cover Size : 145 mm x 220 mm (5.7″ x 8.7″)
*Cover Pile Height : 40 mm (1.6″)
*Cover Stock Thickness : from 80 gsm to 300 gsm
$14,500
MBO T102/4442
Continuous Feed Folder –
Automatic Blow On Pressure Sensitive Labeling Head - Pivoting, rotating head for Top or Side Labeling - Adjustable height - 2" max label height - Air box label applicator - T-stand on casters - Designed to sit over or next to existing conveyor
$3000
Sun HS 3000 GC - (GUTTER CUT)AUTOMATIC BUSINESS CARD SLITTER
BIG TIME SAVER!!
$1900 OR Make Offer
SECAP JET1 TABBER (JUST RECONDITIONED)
ACCUFAST ET/R Dual Head Tabber( Very Nice)
ACCUFAST KT-1 TABBER with ENVELOPE Feeder
$3000
ACCUFAST XL Labeler
$3000 or make offer
Xante HEAVY Duty 4 Color Envelope Printer with Auto Feeder
$4000
XANTE IMPRESSIA 4 COLOR ENVELOPE PRESS with Feeder & Exit Delivery ONLY 700K IMPRESSIONS
$4,000
OKI Digital 4 Color Envelope Printer with AUTOMATIC Feeder & Conveyor Delivery
GREAT CONDITION!!
$5500
1982 Bobst SP126 E - Die Cutter/ Foil Stamping EAGLE SYSTEM & Stripping
ONLY 30,600 HRS!!!
$61,000 ex site
KLUGE EHE DIE CUTTER/FOIL STAMPER 14X22 "(GREAT CONDITION!!!)
$12,000
Kensol KF 500 AP (2"×4") Hot Stamping Machine
$1500 OR MAKE OFFER
PMC F-84 High Die (Great Shape)
PLEASE CONTACT FOR PRICE!
Challenge 370 GPB (37") Cutter with Microcut , Air on Bed. WORKS WELL!
SEE PICTURE
$2900
1992 Polar 150EL with Microcut - Still in PRODUCTION!!
$7000 Plus Loading
KIRK RUDY - Model 219
12 HEAD INKJET UP TO 28X40" FORMAT- 5YRS Old, Customized for Seller- Very Little Use!!! WOW!!!
CALL FOR PRICE!!
1992 Shinohara 66lVK
4 Color
20x26"
Console
20.7mil imp
$15,000 ex site
Sakurai 472ED - 4 COLOR PRESS
Maximum Sheet Size: 14.17" x 20.47" (360 x 520 mm)
Minimum Sheet Size for Straight Printing: 4.13" x 7.09" (105 x 180 mm)
$7500
HAMADA C248 - 2 Color Press
Sheet Size (Max) 14-3/4 ” x 18-7/8″ 365 x 480mm
Sheet Size (Min) 3-1/2″ x 5 1/2″ 90 x 140 mm
3000- 10,000 sph
$3200
Heidelberg 2004 QMDI 46-4 ( 4 Color Press) works well!!
The QMDI press can cost effectively print four-color preocess priniting in quantities 500 to 25,000 up to a maximum image area of 13 by 17.75 inches at up to 10,000 impressions per hour
$4000
HP Latex 360 - 64" WIDE Format Printer- HEADS ARE CLEAN AND WORKING WELL
See youtube below
$4500
Ricoh 1107 EX (BLACK)- LCT, Stacker, Fiery, Stapler Finisher with Plockmatic Square Fold & Face Trim ( 110ppm)
$5500
Ricoh c7100 (COLOR)- 3 LCT's, 2 Stackers, 5th Color, Fiery E-83A
(90ppm)
$9000
Xerox D125 (BLACK)- LCT, HIGH CAPACITY STACKER, Fiery EX125 (125ppm)
$4800
XEROX VERSANT 2100 (Color) - LCT, High Capacity Stacker, Fiery EX125 (100 ppm)
$7800
OCE VARIOPRINT 6320(BLACK)-
3 LCT'S, High Capacity Stacker, Stapler Finisher, Plockmatic with Face Trim (306 DUPLEX PRINTS PER MINUTE)
$9500
CANON C650 (COLOR)- LCT, Stapler Finisher, Embedded Fiery Controller (65ppm)
$9500
contact: sales@specspecsys.com
VERY GOOD CONDITION
$4000
$11500
$3600
$21,000
- Equipped With:
- Maximum Tag Size 140 x 90mm
- Minimum Tag Size 60 x 40 mm
- Maximum String Length 165 mm
- Minimum String Length 100 mm
- $17,500
$14,500
manual feeder
clamp 38 cm,
creasing/milling
110V 60Hz
$2200
Good Condition!
$6800
$14,500
MBO T102/4442
- 4/4/2 Configuration
- R102 Continuous Feed
- Max Sheet Size: 57 x 40″
- Min Sheet Size: 9.84″ x 6.69
- $6900
$3000
BIG TIME SAVER!!
$1900 OR Make Offer
- SPEED
Production Rate:
Single Tab: Up to 30,000 pieces/hr.
Double Tab: Up to 24,000 pieces/hr.
Triple Tab: Up to 18,000 pieces/hr.
(based on 8.5” length product)
Transport Belt:
0 to 600 ft./min. (for tabs <2” pitch)
0 to 375 ft./min (for tabs >2” pitch)
Tabbing Head:
0 to 375 ft./min. - MEDIA
Size:
Minimum: 3” x 5”
Maximum: 13.5” x 17”
Thickness:
Minimum: 20# single sheet
Maximum: 5/8”
- Speed: Up to 20,000 pieces per hour
- Tabs Applied: Up to 3 tabs per pass
- Document Sizes: 3.5" x 9" H x 5.5" - 12" W
- Document Thickness: Up to 1/4" thick
- Tab Sizes: 1" or 1.5" tabs; paper, translucent or clear, up to 12" diameter tab roll (3" core)
- Dimensions: 20" L x 19" H x 31" W
- Weight: 80 lbs.
- Power: 115V, 4A, 60Hz or 230V, 2A, 50Hz
$3000
ACCUFAST XL Labeler
$3000 or make offer
$4000
$4,000
GREAT CONDITION!!
$5500
ONLY 30,600 HRS!!!
$61,000 ex site
$12,000
$1500 OR MAKE OFFER
SEE PICTURE
$2900
$7000 Plus Loading
CALL FOR PRICE!!
4 Color
20x26"
Console
20.7mil imp
$15,000 ex site
- Max paper size: 52x72cm.
- Max print area: 50,8x71cm.
- Max Speed: 12000
- $19,000 LOADED ON TRUCK
$7500
3000- 10,000 sph
$3200
$4000
See youtube below
$4500
$5500
(90ppm)
$9000
$4800
$7800
$9500
$9500
