hp indigo 5000 oil over flow in the startup
Discussion in 'HP Indigo Digital Presses' started by Sergio Serge, Sep 7, 2023.
  1. Sergio Serge
    Sergio Serge Senior Member
    Jan 2018
    102
    nj
    hello guys i have a weird problem with my indigo 5000 when i start in the morning worming up the machine it overflow over the blanket and the oil go true the suction air for couple minutes
    i did adjust the cleaning station flow it looks normal any idea ?
  2. Impredisa
    Impredisa Member
    Jul 2021
    47
    El Salvador
    Check the cleaning station connector and cable, it may get damaged and short, causing IO flow problems, it's a mess when it occurs. If the cable and connector is fine, then you could check sponge roller, and just at last recalibrate the flow or adjust your systab parameters.
  3. Sergio Serge
    Jan 2018
    102
    nj
    I checked the wires looks fine no shortage i did change the sponge roller and calibrated the oil flow i checked the piping all looks good ,what driving me crazy its why is doing this over flow only in the startup, once i clean the dripping oil and get the machine ready again it work normal until the end of the day
  4. Impredisa
    Impredisa Member
    Jul 2021
    47
    El Salvador
    That's pretty weird as I had that issue before on a 5600, and the symptoms were basically the same and only after changing the wires it was solved. But ok, I'm sharing you my systab editor parameters for the flow topic, you can compare to yours and try to tweak a little and see if it helps. I trust this more than calibrating through the wizard. It's from a 5600 I think the cleaning station is the same on both machines. It currently pumps 2.96 liters/minute on my press and I think that's the best setting for the pip to last more.
  5. Sergio Serge
    Jan 2018
    102
    nj
    Big difference in numbers here is my numbers attached
  6. Impredisa
    Impredisa Member
    Jul 2021
    47
    El Salvador
    Well, it looks at decent range man. Did it overflow oil again today?
    The only two things left I can think of, is a problem with the Imaging Oil pump, or the Cleaning Station Motor.
  7. Sergio Serge
    Jan 2018
    102
    nj
    it did it this morning so i stop the machine right away than i click get ready and it was fine
    im suspecting that the pump start before the cleaning station motor somethings like that just in the start its weird
