what you need ?
i have some ... also all these parts
Parts number Description Qty
Q5350-00010 Pip underlayer 3,4,5000 64
Q4403A Pip underlayer 6000,7000 7
MCH-1390-42 PIP underlayer 1000/2000 15
Q1292-60210 Pick roller rohs sv 2
CA245-26340 PIP EHANCING UNIT SERIE 2 9
Q5202A Cleaning station wipper 1
Q5201A cleaning station wipper 16
MKT-1038-01 kit wipper cl short 20u 10
0100-2395 Filter I/O 10 MICRON L270 mm 16
CA290-10490 OZONE FILTER 18
MFL-1900-03 parker filtration 50
673 5812 MFL-0013-01 Filter carbon 620 drager 52
3150-0957 FILTER FOR VACUM SMALL 1
MPX-3472-52 Clamp gripper 2
CK911A GRIPPER 2
CA397-00411 Gripper 8
CA290-09370 Grid scorotron 26
MKT-1037-02 Grid scorotron 8
MKT-1036-02 Grid scorotron 8
MKT-1035-02 Grid scorotron 7
MKT-1049-01 Kit grid scorotron 2u 90
MKT-4016-01 Kit doctor blade 1
MPX-2495-03 Grid scorotron 24
MPX-2494-02 Grid scorotron 4
EBP-0070-90 Module high voltage BID 2
EBE-1057-57 BAOARD ASSY TMBI 1
EBE-2021-57 Board assy ECN ( engine C) 2
EBE-2023-53 Board assy POP-13 xp&nt 2
EBE-2032-56 Board assy TMB3-TESTED 1
EBE-1080-52 Board assy SPI 1
EBE-2050-53 Baoard assy PTI Tested 1
EBE-2027-53 Board assy TSI 1
CA245-08096 Bid tube assy bid#1 1
CA257-00080 Board assy 12
CA254-02450 ITM heater lamp assy 9
CA257-00103 Board assy ISDV TESTER 1
CA257-00101 Board 1
EAS-1229-52 Indigo 1000 2000 Wiper 5 Motor 1
EAS-2160-51 IMAGING OIL PUMP WIRED
EAS-1250-56 TMBI ASSY WITH TRANS 1
EAS-2218-51 ITM LAMPASSY 205v for SBN 3
EAS-1054-51 pump 1
CA345-35971 pump assy CD add 1
CA345-33371 Sic assy press 1
CA345-33712 bid turf assy 1
CA390-07200 Drive motor assy 1
CA397-02931 cariage mecanisme 1
CA345-36291 ink tank assy drive 1
CA254-01220 Main Motor inv-sbn bal 1
CA292-02780 kit image charing camera 1
CA245-14940 small solid add assy 1
CA345-12961 solid assy -LIC 2
CA345-21980 Air mainfold 7 +1 station 2
MKT-3822-01 Kit sofsub instal devic 2
CA244-06641 under c/s bath tech assy 1
CA245-19260 heat exchange with fitt 1
CA245-07300 H.E TOP assy 1
CA245-20830 valve holder and white 1
CA245-12451 cooler ink tank serie 2 1
Item: 5189-2057 stacker main board revc 1
5188-8575 Flipping wheel kit 28.2 2
5188-8656 feedeer multipick divert 1
5188-6591 feeder air chamber 1
CA297-01750 SP5500,3550 air knife T 1
CA245-13504 cleaning station assy 1
CA245-13503 cleaning station assy 1
CA345-41770 1
CA245-05840 Electro mter -assy 1
CA290-01480 Kit-duplex conveyor SE 3
CA397-04150 SP7000 gripper shaft An 1
CA290-02941 KIT RPLC , ITM Beaving RE 1
CA297-00150 SP INK PUMP MOTOR 12
CA290-05010 KIT SUCTION CUPS 5000 set 36 15
MKT-1060-01 KIT SUCTION CUPS 30/30 set 36 8
CA245-06302 LOWER FEEDRE ASSY 1
Item: 5319 97 207 LOWER FEEDRE ASSY
CA292-02760 VALVE 1
CA245-08630 Piping system assy 1
EAS-1050-43 PUMP MOTOR WIRED 2
EAS-2082-52 Snsor temp IR wired NC
EAS-1265-51 MOTOR OPC ASSY 1
MPX-0140-55 SCOROTRON Motor braket 1
MPT-7899-52 Steeper assy 1
Item: 3140-1099 motor steeper with cone 1
Item: 3140-1103 motor steeper motor assy 2
CA244-00240 CONVEYER MOTOR ASSY 1
MPX-6489-62 OPC ENGAGE F.ASSY 1
0100-2301 Valve solenoide 3/4 in 1
CA245-03261 BRACKET MOTOR ASSY 1
CA245-09324 STOP ST ASSY 1
P/N: 414115-001 Assy, MNTG H/W R/T2200 ups 1
MPL-1105-01 Belt flat L = 435W=19 2
PH205A DVD +/-RWx16 Dual layer 1
CA297-00321 Computer assy HP xw4300 2
CA245-06671 Endcap scorotron fro 12
CA297-01551 Kit spare part rear end 7
CA140-06580 housing rear 1
CA297--01550 Kit spare part Rear end 4
CA297-01510 RUBER SUCKER-HAMADA 3
CA245-03510 Stop station assy 1
CA245-09322 stop station assy 1
CA245-08081 sensor IR reflective ,7 1
CA245-06210 Sensor IR reflectiveb , 2 1
CA245-00072 1
MPX-0088-51 R.R Blade holder assy 1
MPX-0135-61 HNDLE ASSY 1
MPX-4944-56 Slit injector assy-TE 1
MPX-0089-52 BLADE w.r assy 1
EZO-2111-02 Brush cooper /carbon allo 16
MCC-3235-01 MOTOR 1
MSL-1010-01 Coil 24V 10W GEM 1
CA245-26930 Exit roller assembly 2
CT245-28471 Exit roller 2
MPT-1078-51 Sponge roller 10
MPX-7722-52 Exit roller assy 1
MPT-7782-31 FEED ROLLER 1
CA345-27820 ROLLER 15
MPX-3693-31 SPONGE ROLLER SP 11
MJX-1336-51 SOFSUB instal jig assy 6
CA345-00755 SPONGE ROLLER 6
MCC-2775-01 4th feed roller 1
CA145-02160 REVERS roller assy Tes 1
CA245-26930 Exit roller 1
MPX-7683-51 Wipper-1 ass1 3
MPX-4875-52 7th Wipper assy 2
MPX-4859-53 wipper 2,4 assy 3
CA292-01830 Duplex shift drive 1
CA261-08940 Cable assy w894 1
MPX-2276-02 Gear -99T 1
MPX-3675-54 1
MPX-3472-52 CLAMP GRIPPER 1
MKT-3409-01 5
MPX-1197-01 1
MPX-2168-02 Seal rool 4
MPX-2660-04 Wipper drum 2
MPX-2160-04 1
CA245-01201 3-way valve assy 1
CA245-16541 PIP HOLDER ASSY 1
MPT-1807-01 12
MJX-0996-51 Cork assy 1
MPT-0472-51 Bid engagement motor 1
MPT-2419-56 INTERLOCK ACTIV ASSY 1
MFL-2167--01 FILTER ELEMENT ( vacum c) 2
MPT-1306-01 spacer-leveler 10
MPT-0113-56 I.O tank mecanical AS 1
MPT-2664-54 BID COVER ASSY 1
MKT-1222-01 KIT SAYAMA ACTIVE FILTER 1
Mpj-2020-01 Tub water drain 1
MJX-1111-90 jig wipper motor drivers 1
MJX-6801-51 PRESSURE GANGE ASSY 1
MJX-6975-52 CONTACT RR-WRDEV 1
MCC-2180-01 Belt compressor 2
MCC-2109-51 Stop finger knob assy 1
EHE-2126-52 Cable assy w126 2
EHE-2036-53 cable assy w36 1
MPX-3934-02 Support bearing 1
MPT-0534-01 Bracket pump magnets 1
MCC-2169-01 Belt main drive rear 1
