How to reduce PH in Damping water ?
Discussion in 'Mitsubishi Printing Presses' started by Mitesh Raval, Jan 12, 2019.
  1. Mitesh Raval
    Mitesh Raval New Member
    Jan 2019
    Ahmedabad
    Maintain pH level for printing is between 5 to 5.5 pH
    And Conductivity is between 800 to 1800.
    How to reduce pH ?
  2. Andrei83
    Andrei83 Member
    May 2017
    60
    Russia
    Why You Need It? The manufacturer of the supplement recommends dosing. Follow the recommendations.
  3. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,054
    Vermont
    modern fountain concentrates are ph buffered to run with little variation in ph. You would probably have to either add or reduce your fountain concentrate a huge amount to effect a small change in ph. I would as mentioned mix it to manufacturers formula and focus more on your conductivity.
