How to disassemble this engine
Discussion in 'Heidelberg Printing Presses' started by ali 120, Apr 11, 2025.
  1. ali 120
    ali 120 Member
    Jan 2023
    92
    Egypt
    I want an explanation or a video on how to disassemble the parts of this engine because there is a problem with one of its parts and I want to replace the damaged part with another part
    [​IMG]
  2. Mathew
    Mathew Senior Member
    Apr 2010
    597
    Kolding-Denmark
    The only part that can be disassembled is the gearbox above the black ring. However, this won't help with the repair since the issue lies inside the motor itself. It's best not to waste your time—consider purchasing a new one instead.
  3. ali 120
    ali 120 Member
    Jan 2023
    92
    Egypt
    Is it normal for the engine to feel heavy when turning by hand?
  4. Mathew
    Apr 2010
    597
    Kolding-Denmark
    Yes, it's a geared motor and you are trying to turn it from gearbox. Apply 24VDC and see if it's turning.
    ali 120 likes this.
  5. ali 120
    ali 120 Member
    Jan 2023
    92
    Egypt
    How to know the engine revolutions if there is no data on it
    Is this determinant in a red circle the number of engine revolutions per minute?
    [​IMG]
  6. Mathew
    Apr 2010
    597
    Kolding-Denmark
    What is the problem with this engine?
  7. ali 120
    ali 120 Member
    Jan 2023
    92
    Egypt
    I want to know the engine RPM because there is another engine but it doesn't have data to know its RPM I want to make it install instead of the old engine
  8. ali 120
    ali 120 Member
    Jan 2023
    92
    Egypt
    In addition, when changing one gear set from another, there is a great deal of difficulty in connecting the gear set, but the old set is connected very easily.
