That little white dial in the window on the NOPS...
The most accurate way to check the buckle setting of the feed roller is to feed a sheet in until it hits the head stop, then get out the hand wheel and look for the exact moment the upper steel feed roll contacts the sheet. Stop there and walk around to the non operator side and look in the little window at the white dial. The pointer should be at 0. Walk back around and using the hand wheel and slowly rotate the press until the moment the feed roller lifts off the sheet. Walk around the press and look at the dial, you want to target 34, 35. Do this a few times to make sure you get an accurate reading, and adjust the knob a few clicks at a time. Hope this helps!
