Jeff
The customer expectation document doesn't set much of an expectation for accurate registration within +/- 1.5mm lead edge and +/- 1.7 mm side edge.
Am I reading this right that on a given sheet registration could be either + or - 1.5 mm for a total variance of 3mm offset in a run? This would seem to make cutting and folding quite difficult.
Is registration typically this loose real world when printing from the oversize high capacity feeder?
Can a careful operator do anything to tweak registration (e.g. using image shift, can you get registration right on and count on it being fairly accurate throughout the run even if you have to re-tweak registration for the next paper/environmental change/etc.?)
